black smoke :(
Old Sep 13, 2009 | 10:42 AM
Mightymike2000ss's Avatar
From: Home town Clive,IA current town FORT BENNING GEORGIA
Default black smoke :(
hey guys last night i did a few pulls with a couple buddys of mine, well every pull i did they said black smoke was just shooting out of my exhaust. the car has brand new heads prc 5.3's and a brand new ms3. i have a mail order tune from texas speed also with 42lbs injectors, my buddy told me that its because my injectors are to big he said for set up i want to use 30 lbs. i dont know whats wrong with my car but i dont like will some one give me some advice
Old Sep 13, 2009 | 10:45 AM
BlueBird346's Avatar
Black smoke usually means its rich.
Old Sep 13, 2009 | 11:01 AM
bongva's Avatar
maybem the gap on your plugs are too big? or the plugs are not good anymore. happened to my brothers car.
but yes you might be running rich like bluebird said
Old Sep 13, 2009 | 11:21 AM
thanks for the input guys im going to try this i was told out of the box ngk's are alright and dont need to be gaped. what size gap do i want
Old Sep 13, 2009 | 11:58 AM
Tyler valo's Avatar
42lb injectors are kinda big for a NA 346. My 418 has 42lbs injectors and they're not even close to being maxed out.
Old Sep 13, 2009 | 01:01 PM
DaddySS's Avatar
If you didn't give texas speed the 42lb injector spec the tune will be way off. You probably only need 30lbs but step number 1 is get it tuned - black smoke means your fuel ratios are way off - and not only is it robbing power but it's not good for the engine.
Old Sep 13, 2009 | 01:04 PM
a buddy is loaning me his 30lbs how do i spec them exactly when i gave tsp my my list of **** to tune i just put down svo 42lbs injectors
Old Sep 13, 2009 | 01:13 PM
Cobra R's Avatar
Its in the tune. I have SVO 42's in my car, no black smoke. Really need to get it tuned with a wide band O2 sensor.
Mail order is going to be a little on the rich side to play it safe. Dont want to lean it out.
Old Sep 13, 2009 | 01:14 PM
Tyler valo's Avatar
Since you have SVO injectors they are 42lbs at 43psi.
Old Sep 13, 2009 | 04:28 PM
i figured that i need a tune but the closest place from where i live is speedinc which is 6 hours away, and the way i see it drive 6 hours for a tune which could cause my car to crap out. that 6 hours is to far away in case something happens.
Old Sep 13, 2009 | 05:32 PM
Cobra R's Avatar
Call TSP, see what they say. See what software they use. Maybe you can find a local to do some data logs with a wideband and send them to TSP to correct the tune some.
Old Sep 13, 2009 | 07:19 PM
damn man hahaha your right with my buddy he is bringing over his aem air to fuel ratio meter he said he was going to log it and im doing my bbk intake install next wednesday and sending it back to get a retune so. ill cal tsp and let them know
Old Sep 13, 2009 | 07:34 PM
what should i log though
Old Sep 13, 2009 | 07:38 PM
Cobra R's Avatar
Basically they should need throttle position, rpm and wideband o2 reading. They should be able to work with that.
Old Sep 13, 2009 | 07:48 PM
holy **** your a life saver man
Old Sep 13, 2009 | 08:29 PM
Cobra R's Avatar
Hope it works out for you.
Old Sep 14, 2009 | 05:35 PM
one more thing my buddy said the i might need to take a read on my tps, or measure the voltage of it. if so how would i do that?
Old Sep 14, 2009 | 06:40 PM
Cobra R's Avatar
Really your best bet is to call TSP, see what tuning software they use. Then locate someone local that can log it for you and send the file to TSP.
