H/C/I Help or suggestions.
Old Sep 22, 2009 | 01:03 AM
TempleU_WS6's Avatar
Default H/C/I Help or suggestions.
Ok, so on my budget I've pretty much decided to use my stock short block and go with a head, cam and intake set up.
I've been thinking so far MS4 with PRC 2.5 LS6 heads and FAST 92mm intake with 92mm TB.
Now a little background info,
Current Mods are Full exhaust and lid as well as a bunch of irrelevant suspension stuff.
car is an M6 with 61k miles.
Not a DD what so ever (under 5k a year) so I'm looking for something aggressive. Will track it once I get a new rear, but will take it easy till then.
Now im looking to make over 450rwhp/tq. Should hit that easy with this set up right?
Also I've done almost everything on my car myself but should I trust my self to install the heads and cam myself or go to the pros?
Old Sep 22, 2009 | 01:16 AM
transamfreak01's Avatar
yeah sounds like a decent set up.. whats your budget? can you afford a better set of heads ?
Old Sep 22, 2009 | 01:17 AM
My budget is looking around 3-4k.
What other heads would you suggest?
Old Sep 22, 2009 | 01:21 AM
well for your budget i would spend the money on h/c before the intake. something like an afr trick flow or prc 215 would be best in my opinion. i would match it with a 230+ cam. then i would save for the rear. for the money spent on the fast set up youre almost halfway there to a stout rear end
Old Sep 22, 2009 | 01:31 AM
Hmm, thats a though. My stock LS6 should suffice right? How much would I really gain with a fast set up?
The afr, trick flow and prc 215 heads are so expensive over the others. Are they really worth the extra money? How much of a gain will I see with them?
Old Sep 22, 2009 | 01:45 AM
john at texas speed quoted me 2600 for prc 215s and cam. the ls6 will be fine. and yes the heads mean a lot. there are a few builds between 460-480rwhp through an m6. is yours a4 or m6?
Old Sep 22, 2009 | 02:17 AM
M6. 460-480 would be nice.
I plan on calling up texas speed an getting ideas and info from them as well as Fran from Race Proven Motorsports. Thats where I got my dyno tune done and those guys too great work.
Wanted to hear what most of you guys have to say. Hopefully more people chime in.
Old Sep 22, 2009 | 01:46 PM
Ok, so a little more help....
Looking into the higher end heads the combos would be over a grand more for them. How much am I really going to see over say the PRC 2.5 LS6 heads with an MS4?
With the difference I could get a new clutch and flywheel which would be nice cause the stock one is starting to give. Also would it be worth it to get 4.11s for my 10bolt till I have enough to get a build rear?
Little help here!
