Need some Patrick G advise
I'm thinking abut changing out my custom camshaft with another one.
When I modifed my engine last year I was looking for a way to make my car faster without losing any of the drivability.
Its a 2000 C5 with A4, LS1, homeported 243 w/ PAC 1518s, .040 Cometics, LS6 intake, ported TB, Vararam w/o MAF, SD Tune, 216/220 cam (.600/.606) 113 LSA actual specs, C6 Z06 exhaust manifolds, cats and H-Pipe, stock catback, built A4 w/ 2200 GM converter, 3.15 diff., 6350rpm shiftpoint
I have a underdrive pulley lying around ready for install and I was thinking if there was a cam available which would provide me almost the same low end torque but a bit more high end power that I could install at the same time.
Since its my daily driver I look specifically at fuel economy with rpms under and around 1800-2000 but would also like to have some more pull above 4500.
I specced the current cam by myself after reading alot and using some engine calculators. It was originally a 214/219 LSL/XFI cam on a 111LSA but came out of production as stated above.
I haven't been on the dyno with vehicle after the swap but my only trip to the track gave me a 12.7 @ 112mph on street tires with lots of tire spin. Not fast enough for the mods I think. Due to my current compression and the small cam I have the suspicion that I can't make full use of max timing (21-24deg gives best performance right now).
I have read in the past about your 223/227 torque cam which sounds great but I'm unsure if it will give me similar low end torque as the one I have now.
Also, based on my previous cam choice I was planning for LT headers, but due to stock appearance requirements I settled on the C6 Z06 manifolds, which are very nice but not quite like LTs.
So now I guess I would probably benefit from more exhaust duration, although the pipes are dual 3" up to the catback.
I would appreciate it if you could give some ideas and direction on where you would go.
Thanks
Alex
I talk about the LS7/LS9 manifolds, cats and h-pipe. These parts support the 505hp of Z06 and the 638hp of the ZR1. There are four individual hydroformed tubes inside this manifold. From research in the C6 community, people are only 10 hp or less behind LT peak hp numbers, torque for the LTs though might be higher. But these are hands down some of the best manifolds/shorty headers available.
If you haven't seen this thread yet, it could be a step in the right direction for you. Look at the VE's of the prescribed cam compared to your current one (apologies, as I guessed at your ICL).
216/220 113+0 218/230 115+4 IVO -5 -2 IVC 41 40 EVO 43 54 EVC -3 -4 Overlap -8 -6
I read about the new EPS cam lobes. What are the sizes they are available in and how would they compare to my LSL lobes on my cam?
For a new cam, I don't mind having a slight lope from the cam although I would like to retain emission compliance.
I'm also kinda unclear on the 218/230 example cam that was used in the link you posted.
What was the reason for the 115LSA +4 advance. How would a 112LSA +0 behave?
Thanks
Alex
218/230 115+4 218/230 112+0 IVO -2 -3 IVC 40 41 EVO 54 47 EVC -4 3 Overlap -6 0
Because the Z06 manifold are so much better than logs, you can afford to go with a little more overlap. In this case, I'd go 1 step bigger than the 218/230 and go 222/230 .597/.600" 114LSA +4 advance. This is with the EPS "endurance" lobes from Engine Power Systems. Strong power under the curve and it will rev to the moon. It will be ideal with your beehive springs.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
thanks for your comment. From my calculation I would end up with -2* overlap instead of -8* with my current cam. How much more lope would that mean (idle rpm 700) and would I fail emissions or would it be borderline? What exacty would fail for emission testing?
From a DCR standpoint I would only loose a very slight amount and end up at 8.4 instead of 8.5.
What I'm concerned about is the low rpm torque that I like so much. Right now I'm able to cleanly pull away from 900rpm in locked 3rd gear (~22mph). If the new cam could do that from 1000-1100 its OK, but if I need to be at 1500rpm that would not be good enough. I know these parameters are hugely affected by the tune but the cam finally dictates the drivability.
For the future I plan a ported FAST 78. Again, low rpm torque and fuel economy are important. Would the cam choice be the same?
Last question, what power difference would you expect from the 222/230 compared to my 216/220?
Thanks alot,
Alex
How do you think about these alternatives and would they sacrifice a lot peak power?
Thanks
Alex
Thanks alot,
Alex
You do not pull from 900 rpm in 3rd (looking for trq band at that level), you should downshift to 2nd.
The cam Patrick speced also has different lobes than what you have and the Ve's are spot on for your application.
Bottom line if you are looking for more, you cannot expect it to drive like the one you have, it will be slightly different.
The more agressive lobes, higher overlap of PG cam will net you more peak power and better undercurve than your 216/220.
Also -2* overlap will pass emmission sniffer with a "lean" tune. (which can be readjusted after test).
Mark
Another option that I came up with is a LSL lobed 219/227 LSA114 +3 , -5 overlap. It will probably come out a bit larger in duration like most Comp Cams and slightly shorter in lift.
Unfortunately the EPS lobes only come as 226 and not 228.
I feel better if I err on the smaller side to retain low rpm drivability.
Would I be OK with my PAC 1518 springs?
Thanks
Alex
