stroker/windage tray interference
Old Sep 30, 2009 | 07:24 AM
forcd ind's Avatar
Default stroker/windage tray interference
i am getting ready to swap out my 6.0 for the 403 i built, and use a caddy CTS pan setup-i have heard there sometimes is an interference problem with a stroker-should be obvious, but is it the throws or the rods that hit-i'll ck everything, but curious what areas to look at-also, is their a dipstick problem,
thought i had heard of that also
thanks
Old Sep 30, 2009 | 09:12 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
You will need to shim the windage tray down with a couple flat washers to clear the aftermarket stroker components.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Sep 30, 2009 | 09:54 AM
performinnorman's Avatar
I shimmed and even reformed the metal in a couple places.
Old Sep 30, 2009 | 10:04 AM
forcd ind's Avatar
will it move the oil pickup closer to the pan bottom, or not enough to worry about
thanks
i am using main studs
Old Sep 30, 2009 | 10:36 AM
Yes, it will move the tube. Bend the tube as needed to get the pickup to pan clearance about 3/8"-1/2".
__________________
