5.3l engine piston re ring? yes/no.. help.....
Old Oct 3, 2009 | 10:09 PM
7deuce-ss's Avatar
Question 5.3l engine piston re ring? yes/no.. help.....
well i have blow by the rings,i know some is normal but i rather be safe then sorry, my question is can i just re ring the pistons with new stock rings and de glaze the bores and be done with it? ive heard that on the 99-00 blocks they had alot of piston slap and was told my best bet is just to bore it out.
trying to keep cost down so shoot me some help...
thanks
Old Oct 3, 2009 | 10:13 PM
NemeSS's Avatar
thanks
how many miles?
depends on the cylinder walls. if was me i would just rebuild the engine with new bearings and parts. and overbore. cheepest and quickest, find a low miles drop in engine.
Old Oct 3, 2009 | 10:22 PM
7deuce-ss's Avatar
they said it had 50k probably been sitting for a while though... i bought it for 500 and then found out it had low compression so i sent the head out, now the heads have 150 set presure.. but the rings had some blow and i dont want to put the heads on and take the chance, then have to buy head bolts and gasket again because compresion was low.
am just stuck it thinking mode...
i think ill be good but theres just that what if.
Old Oct 4, 2009 | 10:36 AM
7deuce-ss's Avatar
any other recommendations?
Old Oct 4, 2009 | 01:06 PM
5_02ls1's Avatar
have the block bored to 3.89 and find a take out set of ls1 pistons....ive bought pistons and rods together for less than 100 bucks....just a cheap alternative to pistons....
Old Oct 4, 2009 | 08:15 PM
7deuce-ss's Avatar
am trying to stay with stock bore and not get more into it..
