Help with compression!
Old Oct 10, 2009 | 11:31 PM
frazierboy98's Avatar
Ok have it.Good luck with your build.Hell it sounds like u need to get predator z to build it LMFAO.Later.
Old Oct 11, 2009 | 09:35 AM
novaflash2002's Avatar
from the looks of it you joined the forum this month. pred z is a very smart gentleman, especially when it comes to cams. he knows his grinds. if you do a small search you will see there are quite a few gentleman running cams that he specd. He was trying to correct what you were saying, but alttile advice. for every .006 a head is milled that is = to 1cc.
Old Oct 11, 2009 | 10:33 AM
Yes I know this if you would READ what I stated .018 would land his right as stock heads are 66.7cc milling .018 which is very popular would give him the same as PATRIOT 64cc.How hard is it for every1 to comprehend if he finds how much HIS HEADS HAVE BEEN MILLED THATS A SURE ANSWER TO WHAT CC TO GO BACK WITH MINUS ALL THE OTHER INFO THATS BEING PASSED AROUND PERIOD.Now go go back and read everything I wrote and quote on that!Have a nice day.
Old Oct 11, 2009 | 10:48 AM
Did I or did I not say .018 would put him from the stock 66.7 to about 64.5 I believe that was somewhere btw my 1st and 3rd quote and just so you know 1 cc is between .006 and .007.So thanks for the info.
Old Oct 11, 2009 | 10:52 AM
Btw when the **** does joining the forum have **** to do with my knowledge of cars?It dont Ive worked at GM ive worked on cars since I was 15 so do yourself a favor and dont step in on something you dont know anything about!
Old Oct 11, 2009 | 11:09 AM
you were calling out a guy that has a ton of knowledge. i wasnt trying to make it look like you were stupid, i was trying to make you aware that pred knows his stuff. btw i dont care how long you have worked on vehicals, its just funny you can tell who is young and doesnt understand forum talk.
Old Oct 11, 2009 | 11:17 AM
Im grown thanks 29 to exact.I wasnt calling him out either I gave my insight and was "corrected".All I was doing is stating a fact.Have a nice day.
Old Oct 11, 2009 | 12:07 PM
Thimble's Avatar
Originally Posted by frazierboy98
but if he does have a bigger lift cam I tell u what you throw a .620 .630ish cam on an ls1 with a set of milled *** heads and tells us your results!The more you mill a head the less duration and less lift you can put in it.
With that dur and that lift its a guarantee that the heads have not been milled that much probably no more than has been quoted .018
Guarantee, huh.
Using your logic, I guess my setup is impossible.
stock LS1 bottom end
5.3 heads milled .025" by TEA (59cc actual volume), 2.02/1.55 valves
.040" Cometic gaskets
less than 2cc of valve relief
240/244 .609/.614 111 lsa cam.
That put me at about 11.6:1 compression. Actual measured p/v clearance is more than the typical "safe" recommendations of .080/.100"
Since you wanted to hear about results, well it sees 7k rpm quite often, and it's run flawlessly the past 3 years since I put it together.
Old Oct 11, 2009 | 03:00 PM
Originally Posted by Thimble
Guarantee, huh.
I say ur full-o-**** thats my comment for the day! So cheers
Old Oct 11, 2009 | 04:16 PM
Thimble's Avatar
That's because you apparently don't understand the concept of valve reliefs.
Without them, I'd have (-.010") p/v clearance. Minus, meaning interference, direct contact, no clearance at all. About the same as what you might predict.
With .100" deep notches cut into the pistons, I now have .090" p/v clearance. Since the notches were cut at the same angle as the valve, every .001" of depth cut is .001" of p/v clearance created. Funny how that works.
OP, sorry for the mini-hijack.
Old Oct 11, 2009 | 06:10 PM
Wow did you pull that head all by yourself just to prove a point to me lol.Get outta here.
Old Oct 11, 2009 | 06:11 PM
  #32
Wow did you just go pull that head all by yourself to prove a point lol.Get outta here.
Old Oct 11, 2009 | 07:19 PM
  #33
PREDATOR-Z's Avatar
Frazierboy98
What is your deal? If you make a mistake in life, it is Ok to admit it. Continuing to argue about things we have done over and over again, does not add to your credibility or your intelligence.
Sit back and reflect on what you are saying, what more proof do you want?
Old Oct 12, 2009 | 09:05 AM
  #34
he must not have been loved as a child
Old Oct 12, 2009 | 09:51 AM
  #35
BADBOYZ28's Avatar
Originally Posted by PREDATOR-Z
We would have to know
1-What size piston reliefs are in your engine
2-Rod size
3-Bore size
4-Gasket thickness
5-Piston to deck height
to answer your question...
Alright back on topic now. Spoke with LME this morning and this is what I got...
1) 2cc piston relief
2) 6.125 rods
3) 3.905 bore
4) stock gasket
5) ten thousandth out of the hole
He didn't know exactly how much my stock heads where milled but said my CR is about 11 to 1. Hope this helps guys.
Old Oct 12, 2009 | 11:20 AM
  #36
well it should land approx about 10.601:1.with 64cc heads.
Old Oct 12, 2009 | 12:24 PM
  #37
PREDATOR-Z's Avatar
2) 6.125 rods
3) 3.905 bore
4) stock gasket
To get ~ 11:1 you have around 61cc at the moment
64cc will be ~ 10.6:1
Old Oct 13, 2009 | 12:31 AM
  #38
BADBOYZ28's Avatar
What will I have to mill the new heads to get the same 11:1? Would you suggest going any higher on the compression?
Old Oct 13, 2009 | 09:56 AM
  #39
PREDATOR-Z's Avatar
It depends what fuel you like to run on. What do you normally use (which octane)?
Old Oct 13, 2009 | 09:25 PM
  #40
BADBOYZ28's Avatar
All I run is 93 octane.
