valve guide seals???
Old Dec 3, 2003 | 10:01 PM
Kurtomac's Avatar
Default valve guide seals???
why do valve guide seals leak or go bad? are they hard to replace with the heads off the car and what are the costs to do so
Old Dec 3, 2003 | 10:47 PM
CAT3's Avatar
Restricted User
Valve Seals, easy enough to replace on the car, ultra easy off. Valve guides, thats a different story. Take those to a machine shop that deals with heads! Seals go bad from many reasons, low oil, age, heat etc...
Old Dec 3, 2003 | 10:59 PM
Kurtomac's Avatar
thinkin bout buying 10secondz stage 2 TEA heads 3000 miles on the heads....says the exhaust side seals are leaking why would that happen being so new...how much are the seals?
Old Dec 3, 2003 | 11:01 PM
Kurtomac's Avatar
also ive never really heard much about comp 987 dual springs(which come with the heads), i have a 224 581 112 cam im sure theyd work with my cam but what are they rated for and how often should they be changed?
Old Dec 3, 2003 | 11:49 PM
SNW Vette's Avatar
Question Aftermarket Seals
Hi,
Anybody know were to buy aftermarket 8mm seal to fit the stock valves & guides? I have only been able to find 5/16".
Thanks,
Steve
