Would Comp Cams 918 be enough?
Old Oct 11, 2009 | 02:53 PM
99SSAGUI's Avatar
Default Would Comp Cams 918 be enough?
I am planning an engine rebuild and for the top end I am looking at TSP 5.3L stage 2.5 Heads milled to 59cc and a Trick Flow cam with 228 int./230 exh and 0.585 in. lift on both intake and exhaust. My question is would the Comp Cams 918 (.600 lift) single spring would be enough or should I step up to a PRC double spring (.660 Lift).
I know that it is best to be safe than sorry but I don’t know if the PRC sprigs will be overkill and put unnecessary strain on the rest of the valve train. Someone who knows their stuff please chime in as I really don’t know much in regards to springs.
Old Oct 11, 2009 | 04:47 PM
'02 WS6's Avatar
The 918s will be fine.
Old Oct 12, 2009 | 01:40 AM
transwiz's Avatar
You could use 918, but for piece of mind I would do the duals.I have a smaller cam than you have and I will be changing my pac 1218(same as 918's) to the duals pretty soon.
Old Oct 12, 2009 | 01:42 AM
jetlag's Avatar
Either PAC1218 (.600) or PAC1518 (.650)
Old Oct 12, 2009 | 06:47 AM
outkast6991's Avatar
^^^^^^ listen to this guy. no need to add the weight of a dual
Old Oct 12, 2009 | 07:17 AM
PREDATOR-Z's Avatar
Pac 1518 and 61cc heads
Old Oct 12, 2009 | 11:39 AM
01ssreda4's Avatar
PAC 1518s
Old Oct 12, 2009 | 10:56 PM
99SSAGUI's Avatar
Thanks for the input everyone I think that the PAC 1518's are so far the best choice.
