Help with cams
Old Oct 11, 2009 | 07:29 PM
reamo04's Avatar
Default Help with cams
Looking at lingenfelter cams.
I am swapping in a 5.3 into my 94, so the cam will be going in that.
I am looking at these
GT2-3 207 / 220 .571" / .578" (1.7 ratio) 118.5 centerline
GT7 208 / 230 .554" / .546" (1.7 ratio) 121 centerline
What I want from the car:
Idle like stock, sound like stock, and drive good. I want good low and medium range torque, with decent HP.
Anything over 350 at the wheels N/A, i would be MORE than happy (with full boltons of course)
Now, part of the reason for looking at these, is I am later going to turbo it with probably 10PSI or so.
So, wondering what you guys thought about these?
The other option, would be the TR224 on a 116.
Old Oct 11, 2009 | 07:47 PM
PREDATOR-Z's Avatar
216/214 .561/.559 113+2 lsa
Old Oct 11, 2009 | 08:24 PM
reamo04's Avatar
gonna be too lopey for my tastes.
Old Oct 11, 2009 | 08:29 PM
'02 WS6's Avatar
Don't base "lopiness" on just lsa alone. If the cam Predator-Z gave you has little overlap, it'll have a smooth idle.
I have seen a lot of positive results from the GT2-3 cam though.
Old Oct 11, 2009 | 08:52 PM
WSsick's Avatar
very true. its a common misconception that LSA is the only thing that creates lope or a stock suonding idle. if my math is correct, that grind you result in -11 degrees of overlap. that is going to be one damn smooth idle.
plus, pred z knows his ****, so he wouldnt suggest something that was against what you were looking for.
Old Oct 11, 2009 | 09:42 PM
reamo04's Avatar
i appologize for my hastiness. Who makes that cam, where to get it?
Also, i would not need to flycut pistons would I?
Old Oct 11, 2009 | 09:45 PM
WSsick's Avatar
i doubt it. and its his own custom grind. just take the specs to a sponsor or call up comp cams and theyll grind it for you. no need for off the shelf cams when a custom grind does a better job to fit exactly what you want, with zero or minimal extra charge ($20 for a few places)
Old Oct 11, 2009 | 10:02 PM
reamo04's Avatar
anything bad to say about texas-speed?
i know they provide custom grinds for the same price as an off the shelf
also for that cam, what ICL? edit: nvm, saw he said plus 2, meaning a 111 ICL
Old Oct 12, 2009 | 06:43 AM
PREDATOR-Z's Avatar
-11 degree overlap, no lope, it is setup with your future turbo in mind, but it will be nice and torquey NA,
Specs are:
Comp Cam lobes
Intake # 3711R
Exhaust # 3710R
113 LSA
111 ICL
I recommend PAC 1518 springs with that cam
Degreing the cam and measuring for pushrods as well.
0 PTV issue on stock heads, gasket.
Old Oct 12, 2009 | 02:41 PM
reamo04's Avatar
Specs are:
Comp Cam lobes
Intake # 3711R
Exhaust # 3710R
113 LSA
111 ICL
awesome man. Thank you. I am assuming once i switch to 6.0L heads when the turbo actually comes, i wont have PTV issues either?
Old Oct 12, 2009 | 09:12 PM
PREDATOR-Z's Avatar
Nope, you could put 2 side by side and still clear
