excesive smoke from pvc
Old Oct 16, 2009 | 08:15 PM
rm2500's Avatar
can you cap everthing off except the two back valve covers and tie those together and vent it to a can
Old Oct 16, 2009 | 08:30 PM
JFM-jr's Avatar
Yes you can do whatever you like. No it will not function properly, do you comprehend anything at all that has been posted thus far?
Old Oct 16, 2009 | 08:39 PM
rm2500's Avatar
why does my builder not want exhaust gases going back into the intake
Old Oct 16, 2009 | 09:00 PM
JFM-jr's Avatar
I responded to your PM good luck I hope it all works out. Ask your builder about the smoke you are seeing maybe he can explain it better.
Old Oct 16, 2009 | 09:05 PM
eseibel67's Avatar
JFM: Good job. Your effort was not wasted.
Old Oct 16, 2009 | 10:55 PM
99RTA's Avatar
Do a leak down test...betcha its high on some of the cylinders. That where blowby comes from.
Old Oct 17, 2009 | 07:25 AM
JFM-jr's Avatar
With an improperly routed/vented PCV system smoke/mist/vapor escaping the crankcase is normal very very normal.
Old Oct 17, 2009 | 09:51 AM
99RTA's Avatar
I have to disgree, the PCV system is only able to handle a reasonable amount of crankcase gases. If an engine has HUGE BLOWBY the PCV system will be overwhelmed and large amounts of oil will get forced back into the intake.
I'm not sure why builders don't test BEFORE the engine is in use? If it has alot of leak down its going to smoke and push oil into the intake if the PCV system is used.
A well built engine will have very little blowby and what that means is it has well sealing cylinders. This mean low leak down and no smoke out the oil cap. Also means the stock pcv system will work just fine.
Anyone that has oil and smoke trouble needs to check their leakage and go from there. Whats acceptable leakage for the amount of money you pay??????
Old Oct 17, 2009 | 10:01 AM
99RTA's Avatar
Originally Posted by rm2500
it is like a chimney
but it is constant there is no water in the oil .it did backfire on the dyno
but the power was the same on the next pull
Please have a leak down test done and post up the numbers. Be sure its done with the pistons at TDC and BDC. This will check the entire cylinder for leakage through its stroke.
Old Oct 17, 2009 | 11:59 AM
JFM-jr's Avatar
I would agree with a PROPERLY setup/working PCV system. It "seems" this guy does not and any engine from mild to wild unless running a gapless ring will have blowby escaping into crankcase. I was told by the Total Seal tech Ed an engine can produce 5-7CFM of blowby. It certainly wont hurt anything doing a leakdown test. Tho in this guys case I have a real sneaking suspicion if he setup a properly working PCV his "smoke" issue will be gone. Just my .02
Old Oct 17, 2009 | 02:34 PM
99RTA's Avatar
If yer motor is huffin like a chimney at idle you got serious leak down issues.
