what is the advantage or disadvantage to a reverse split cam?
Of course I really can't say to much as I am throwing a big stick in my ride now. I've had the F1, the TSP 231/237 and now I'm probably going with something along the lines of the TR 236.
BTW - MTI 427 - I ran the TSP 231/237 with some very mildly ported LS6 heads and made 420 rwhp through a 9''. I think that cam and the LS6 heads would be a great combo - just make sure to go with the dual springs just for peace of mind.
Thanks for the heads up and info. How many miles did you put on with the 231 TSP cam and were you running the crane dual srpings. Did you ever break a spring and what springs did you run.
Thanks man!
Stock Cam:
Dyno: 321 rwhp/ 335rwtq
Mods: Longtubes, 2.5" True Duals, Minor Boltons, No Pulley, No Tuning, No LS6 Intake, No Ported TB
Previous Cam:
RPM Stage 2- 232/236 .571/.577 112
Dyno: 381 rwhp/354 rwtq
Mods: Same as above at the time of dyno, still no tuning
New Cam
My custom specs
234/230 .598/.591 112+2
Dyno: 354 rwhp/ 347 rwtq (right around there, I dont remember the exact numbers)
Mods: Same as above at the time of the dyno, still no tuning
Now some poeple might come back as saying lightweight race cars blah blah blah, but dont you think there are others out there just as light or lighter with the big cams? No flames intended just my thoughts..
Phil
Phil
I had about 4-5K miles on the TSP cam when I decided to change setups (sold everything with the intent on going with a new solid roller motor - but alas plans change and now I'm just redoing the heads/cam). Anyway, I used the comp 987 springs with great results. No valve float and no breaks. Granted I did not run them that long - but still no problems. Also, my heads were 01 stock valves so with your lighterweight valves, titanium retianers, etc. you'll really have a nice rev happy set of heads
Feel free to shoot me a PM if you would like to discuss in more detail about either setup as I might lose track of this thread.
Here in Nevada, we have strict emissions, but with the 1996-newer computer emissions testing, it is cam friendly. As long as youre tuned and have no more than 2 codes or incompletes, you pass. Guys are passing with major cams in them.
DAMIAN,
I cleared up my PM box and was wondering if you could resend your message from yesterday that did not go through b/c i was maxed out!
Thanks bud.
