ms4 cam question.
Old Oct 22, 2009 | 02:45 AM
ls1camaro98's Avatar
Default ms4 cam question.
will a ms4 cam fit 243 unmilled heads on a stock lq4 6.0 or will it have issues with ptv clearances? how do you check the clearances to see if it will fit or not?? thank you im sure someone has done this set up before.
Old Oct 22, 2009 | 02:58 AM
lemons12's Avatar
Stock heads (valves) will clear an Ms4.. If you have any questions like this, call TSP directly.
Old Oct 22, 2009 | 08:39 AM
ND2RACE's Avatar
That should have more clearance then it would on an LS1. The LQ4 has a dished piston, but I'd still check it
