ARP torque specs.
Old Dec 6, 2003 | 06:09 PM
landlord's Avatar
Default ARP torque specs.
Anyone know the torque specs on ARP rod bolts
Old Apr 14, 2004 | 08:59 PM
Gen3Benz's Avatar
directions in the package of pro bolts say
.0062-.0066 stretch
or 40 ft lbs loosen, than 40, loosen than 40 again
and it says to use the arp moly assembly lube
also, would i benefit from torqueing with the stretch method?
Old Apr 14, 2004 | 09:07 PM
AnthonyR's Avatar
.0062-.0066 stretch
IMO you should get yourself a rod bolt stretch gauge. It's well worth the 60 bucks and you get piece of mind that the bolts are torqued properly.
