which cam?
Old Oct 22, 2009 | 06:39 PM
TManZ28's Avatar
Default which cam?
Which cam for a stock ls1, going with an ls6 intake and pacesetter LT's and tsp or-y and a magnaflow cat-back. I plan on a 3k stall and 3.73 gears a phr and a complete vehicle bushing kit, its a 1998 z28. I was considering the gmpp hot cam, but have heard it is too small, or maybe a custom cam from straightline performance. Just looking for suggestions, I would like to hit high to mid 12's on this set-up.
Old Oct 22, 2009 | 06:44 PM
01ssreda4's Avatar
tr224 or 224r. Very good match up for a 3000 stall. I would personally match it with a 3600 though.....
Old Oct 22, 2009 | 06:48 PM
02*C5's Avatar
Ok since you have an A4 where are you looking to set your shifty points where do you want you peak HP to be at. Since you have your goal set is it a DD, weekend terror, track only, strip/street. What heads are you going to be running.
A little more info would help because you are going to need a cam to be in the mid 230s with a minimum of a 600 lift for 12s and an LSA in the 109 to 112 at the most if its a track only car. If you do custom grind Pat G, Ed Curtis, Lloyd Elliot would be some of the guys to contact for that type of cam. Also are you going to stick to N/A or are you going to do some type of forced induction. Just a few questions you need to look at before actually choosing a cam.
I am running low 12's with the set up I have N/A, cam from Ed Curtis and heads from Total Flow Induction CHD.
Old Oct 22, 2009 | 07:52 PM
TManZ28's Avatar
I am looking to have a nice street car that can go to the track and crack off 12's whether its 12.99 or 12.59. I have a budget to stick to and what i feel to be a sturdy platform. Unfortunately heads are not in the budget but a cnc of the stock heads is an option.
Old Oct 22, 2009 | 08:29 PM
Dennis@SpectacleSolutions's Avatar
LS1Tech Sponsor
feel free to give us a call. my business partner worked at Comp Cams and specd a lot of LSx stuff while he was there.
our cam prices are also very competitive. We are only minutes down the street from Comp Cams and can custom grind anything you need.
Thanks.
Old Oct 22, 2009 | 08:31 PM
01ssreda4's Avatar
A converter and DRs will get you that easy. No cam needed
Are you talking about a 12 sec 1/4 mile pass? A tr224 and good converter combo with traction will yield high/mid 11s all day. You most certainly dont NEED a 230s cam. Ask me how I know
Old Oct 22, 2009 | 09:05 PM
TManZ28's Avatar
lol well the tr224 is what I thought or a custom grind, but an off the shelf will work. I did mean a 12 second 1/4 mile pass. Thanks for everyone's info so far.
Old Oct 22, 2009 | 10:57 PM
02*C5's Avatar
If I was running DRs I would be in the 11's I am running 12.2 or 12.1 on Nitto Invos my friend. Which is a shitty tire for any type of track use.
Old Oct 22, 2009 | 11:53 PM
thewholefnshow1's Avatar
TSP or TR 228 or Vegeance Racing VRX3 Cam Or VR series cams
Old Oct 23, 2009 | 12:30 PM
00 Trans Ram's Avatar
Think about a "reverse split" like the TR 230/224 .575/.563 111LSA from Thunder Racing. Great power, but still work well on the street.
