what do you suggest?
Old Oct 25, 2009 | 08:15 PM
00Silv4.8's Avatar
Default what do you suggest?
Im thinking about holding off on building a motor as long as I can. Thinking I wanna do some internals, a mild cam, thinking Ill rebuild the top end (seals and lifters, oil pump, etc.) motor has 144k, what do you guys think? will it last?
Old Oct 25, 2009 | 10:34 PM
transamfreak01's Avatar
yeah itll last. whats your budget b/c from what u said about, you are building a motor pretty much. i would do a forged 347 or 383, 23Xcam and i would pick up a set of used ls6 heads
Old Oct 26, 2009 | 11:29 AM
00Silv4.8's Avatar
Im trying to not pull the motor and build a different one, trying to only do lifters, head gasket, valve cover, valley cover, valve cover gaskets. Oil pump and cam. I really rather not do the bottom end but if it comes down to it obviously I will
