Damn.... its just too bad
Everything was running fine after install. went to go and tune the car so i could dyno this past weekend. Tuned the car.... made #1 and #2 wot wideband verification passes and it pulled pretty good. Made appropriate corrections after each. Made the 3rd WOT pass and the motor shuts off at 120mph. Pulled off the road. Thinking fuel pump? Try and turn it over and it cranks just no fire. try for 6 seconds and it fires up. I start to realize that under normal driving i get some oil smoke out of the back on decel and also when doing work.
I guess i damaged some rings with the motor losing fuel. The car never smoked like it does now. It might of had a small puff of oil smoke on decel prior to the new H/C but noting that was constant and only happened on decel after a hard run.
I did a compression test...
#1 = 170
#2 = 210
#3 = 180
#4 = 210
#5 = 45
#6 = 210
#7 = 60
#8 = 210
Checked the leak down on 5&7 after pulling the valve cover and loosening the rocker arms and the only place i could hear air was from the oil fill tube on both cylinders. It was not blowing out of the hole though. I could only hear it.
Sucks regardless.... I wonder why the fuel pump would do that and still work perfectly every time i have started it since.
Sounds like it needs rings since its leaking into the crankcase.
Probably from too long of a WOT pull with it being lean is my guess, but im not a FI tuner.
Killer looking car though, BTW.
It would be amazing if my problem was just the head gasket. Not really wanting to spend $3000 on a newer better bottom end.
Also, you can take a squirt bottle of water and set it on stream. With the motor running spray each header tube and find the one/ones that the water burns away the slowest and thats where the problem(s) are.
Seeing as how you already did a compression test that probably wont help much, but worth a shot if the coolant is low.
