Oil pump
Old Oct 26, 2009 | 03:38 PM
captainstalin`'s Avatar
Default Oil pump
From everything I have researched on the oil pump i have seen no mention to a gasket in between the pump and the block. Is that right? I know there is an o ring to the pickup, but does it just fit hole to hole on the block?
Old Oct 26, 2009 | 03:43 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
it fits directly to the block's machined surface with no gasket. you are correct.
Old Oct 26, 2009 | 05:27 PM
01ssreda4's Avatar
Yep, they are machined flat. Still kinda makes you wonder though huh??
Old Oct 27, 2009 | 08:25 PM
well my heads and block are machine so ipso facto gm shouldnt need gaskets there either lol.
