Missing/backfiring and low cooant
Old Nov 2, 2009 | 06:16 PM
bluebyu8484's Avatar
I know you need to warm up the engine to operating temp, but do not want to put everything back together. If I do a cold engine test, I should be able to tell if the h/g is blown?
Old Nov 2, 2009 | 06:55 PM
BaddBird's Avatar
I think you will be alright doing a cold engine compression test.
Old Nov 3, 2009 | 08:45 AM
I am just concerned the water in the engine will cause damage to the bearings and crank.... not sure how much water there is..
Old Nov 3, 2009 | 09:50 AM
1CAMWNDR's Avatar
Then change the oil and then do the compression test. You will not actually be starting the motor with a compression test so there is no need to refill it with coolant.
Old Nov 4, 2009 | 10:29 AM
UPDATE:
Leak test was good on all cylinders (10-20%)....except #7. Gurgling sound in the radiator and could not hold any pressure. Pulling the head and hoping for just a gasket, but with plug f'd up I am thinking there is more to the story. Water in the engine is the least of my concerns now.
Old Nov 4, 2009 | 10:31 AM
1CAMWNDR's Avatar
Old Nov 5, 2009 | 10:47 AM
Doesn't look good....at least got the intake off yesterday and there is oil in the head #7 intake port. Going to go ahead and take the head off, but it is obviously not just a gasket. Question: Why is it necessary to take the water pump off when removing the heads as directed by JMX?
Old Nov 5, 2009 | 12:12 PM
1CAMWNDR's Avatar
Water pump removal is not necessary. I think those instructions are also for a cam swap. The power steering pump is a pain to get off. Just be ready to take your time.
Old Jan 8, 2010 | 07:38 PM
Ford_Assassin's Avatar
Updates?
Old Jan 8, 2010 | 08:32 PM
Blacklightning744's Avatar
could also be a leaky water jacket
