How much comp can you get...
Milling 317 head to 66cc with cometic .040" gasket = 10.4:1
Swapping to a 243/799 head with 64cc chamber with stock .056" gasket = 10.2:1
Swapping to a 243/799 head with 64cc chamber with cometic .040" gasket = 10.6:1
Swapping to a 243/799 head with 59cc chamber with stock .056" gasket = 10.8:1
Swapping to a 243/799 head with 59cc chamber with cometic .040" gasket = 11.2:1
Results are rounded to the nearest 10th of a point to give you a good idea of what you can achieve with each option.
We can mill PRC LS6 heads down to 57cc.Hope that helps!!
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
