lokar dipstick owners in here!
Old Oct 31, 2009 | 10:51 AM
383lt1impala's Avatar
Default lokar dipstick owners in here!
Anyone else having problems on removing their dipstick? I cannot remove it unless I removed the whole tube with the stick. Maybe its because I have a moroso oil pan or a 4 inch stroke? if u have problems note if u have a stock pan and crank. Thanks.
Old Nov 1, 2009 | 08:33 AM
mknight759's Avatar
mine works ok but my tube is using a header bolt and bracket to hold it in place
Old Nov 1, 2009 | 09:30 AM
DeanJ's Avatar
Mine works fine. My header bolt also holds my outer tube. Sounds like your inner stick could be damaged, and not letting it slide out. Maybe the 4" crank hit it? Dean
