Need Help: Alternators keep dyeing???
Old Oct 31, 2009 | 02:40 PM
FasTimeSS's Avatar
Default Need Help: Alternators keep dyeing???
OK so I have a big problem I keep killing alternators. I have killed 9 in 6 months. So far I replaced the exciter wire, postive battery cable. I am sick and tired of changing alternators what could be the problem. I was good for about 3 months with and orielly new alternator and a new exciter wire. I did a burnout 2 weeks ago and it died during that. I have noticed that with this new alternator that the alternator will die while at WOT but come back. I need to figure this out asap as I can't trust the car as of know. Thanks for the help somebody please help me out.
Old Oct 31, 2009 | 10:44 PM
araber89's Avatar
From: Holmes County (thats right Amish Country), OHIO
Do you have like a wrong sized pulley on there that your spinning it to fast and basically killing it?
Old Nov 1, 2009 | 02:32 AM
FasTimeSS's Avatar
no everything is stock setup. I am stumped at this.
Old Nov 3, 2009 | 12:00 PM
Dmoney's Avatar
Check your PowerSteering pump and hoses for leaks. My PS pressure hose was leaking on top of the alternator causing 4 of them to fry and I didn't realize it was the hose until it finally ruptured all over the alternator and the cars voltage dropped right after it happened...............
Old Nov 3, 2009 | 12:22 PM
Bader-X's Avatar
as Dmoney said check for a lead of powersteering fluid to the alternator first
I had that + my fix was a bigger alternator I think wich was from a 5.3 or 6.0 engine that the shop fixed slightly bigger but he made it fot and the problem was gone
I always had the amp drop to below 13 A after the car is warmed up or running for a while and hot untill he put that alternator.
Old Nov 3, 2009 | 12:44 PM
5.3LJimmy's Avatar
Make sure that your battery is properly secured to the tray. I have seen loose batteries lean back and short out under hard acceleration. It could be grounding out and frying the alternator.
