No Tach and Camshaft Position Senor code
Old Nov 2, 2009 | 12:28 AM
nitr0racing21's Avatar
Default No Tach and Camshaft Position Senor code
my camshaft position sensor code is being thrown and the tach isnt working also I am throwing a Evap code?????????????
I really need some help here guys
Old Nov 2, 2009 | 01:07 AM
KingSS's Avatar
Did you replace your engine?
Old Nov 2, 2009 | 01:51 AM
ae13291's Avatar
i think the cam sensor also controls the readings on your tach guage. sensor should be towards rear of block right under the oil pressure sensor.
Old Nov 2, 2009 | 01:55 AM
Mumbles's Avatar
My guess would be the Cam Position Sensor. Good luck, man.
Old Nov 2, 2009 | 06:48 AM
eallanboggs's Avatar
Evap and cam sensor are unrelated. Have you checked for proper voltage at the cam sensor connector with KOEO? If you don't have ref voltage you can change sensors all day and not solve the problem. The Evap is a leak of some kind. Could be the gas cap seal. Evap is not easy to troubleshoot. You will need a scan tool with bi-directional controls.
Old Nov 2, 2009 | 07:39 AM
Anyone have a picture of the cam sensor? I can't picture where it is.
Old Nov 2, 2009 | 08:49 AM
5.3LJimmy's Avatar
You have to remove the intake to get to it. It goes down into the block right next to the oil pressure sending unit.
Old Nov 2, 2009 | 08:56 AM
5.3LJimmy's Avatar
You can see it in this pic just to the left of the OPSU.
 Michael S. Palmer
Old Nov 2, 2009 | 09:14 AM
what are the odds to get to it without taking out the manuifold?
Old Nov 2, 2009 | 09:16 AM
Jon@Texas-Speed's Avatar
If the tach isn't working, more than likely it is a cam position sensor. Check and make sure it is plugged in. If it is, I would replace it and see if that fixes your problems.
Jon
Old Nov 2, 2009 | 09:22 AM
Ok I will start taking the manifold off now How can I track down my mass air flow sensor low circuit input? I already looked at the fuse
Old Nov 2, 2009 | 09:43 AM
5.3LJimmy's Avatar
You didn't say anything about the MAF code before. With all those issues at once it is starting to sound like you have a ground or power problem for the sensor circuits.
Old Nov 2, 2009 | 02:54 PM
ae13291's Avatar
replace the cam sensor because thats a pretty important sensor, some other sensors work off of it.
Old Nov 2, 2009 | 03:09 PM
mwatson185's Avatar
I thought the tach ran off the crank sensor, not the cam sensor. Can anyone verify that it runs off the cam?
Old Nov 2, 2009 | 03:13 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Cam sensor definitely affects the tach!!! Check it first!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
