Need help choosing a build!
big cubes big heads small cam
265cc ETP 6 Bolt Heads
Custom Cam 24x./25x. 61x./62. 115 LSA
98mm KYTP Turbo kit
Full Madman/UMI/BMR Suspension
4l80E/TH400 3200 PT stall
325/40/17 Hoosier Drag Radials CCW Drag Pack
3.50 Gears M9 35 Spline Axles (you said this was already going in)
Big Stuff Three with 2 step and a dedenbear lighting delay box to dial in the 60 ft.s and 330's to hook all that power unless the BS3 can do all that which I think it already can.
That should get you running low 9's high 8's.
Do a 434ci to keep the stroke at 4"...4.155 bore. You can spray that thing with a 300 shot for years and years. Should make close to 1,000+ RWHP on the spray. And drive around great for a daily driver.
