stock rocker ratio
Old Nov 10, 2009 | 04:55 PM
zflewbyu's Avatar
Default stock rocker ratio
whats the stock rocker ratio on an ls1? thanks
Old Nov 10, 2009 | 05:03 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Stock is a 1.7:1 rocker ratio
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Nov 10, 2009 | 05:04 PM
zflewbyu's Avatar
Was also wondering if going to a diff ratio would be a good idea car has a tick polluter cam 242-244 612-610 112 lsa rest of the motor is stock would it be ok with a higher lift?
Old Nov 10, 2009 | 05:09 PM
If you're running stock heads, I'd stick to the 1.7's. Your heads really don't flow better up there at almost .650" lift than they do at .612", so you wouldn't see any major difference in power. I'd run the stock rockers or maybe have them modified with the Comp trunion upgrade kit to give them a bit longer and more reliable life
__________________
Old Nov 10, 2009 | 05:13 PM
02*C5's Avatar
Most off the shelf cams are set to run with a rocker ratio of 1.7 so going to a 1.8 is not a good idea. Also take into consideration how much more lift you are going to end up with.
Bigger rocker ration is just a bad idea all the way around if you are not setting up your engine and valve-train for it from the get. (MY opinion)
The best thing you can do is get an trunion upgrade like mentioned above and you will be good.
