guess the damage:(
Old Nov 10, 2009 | 06:49 PM
outkast6991's Avatar
Default guess the damage:(
anybody wanna tell me what happened after only 15,000 miles. car ran and sounded good
5 lobes are chewed up. this one was the worst. all lifters were free and intact. comp 918's. sorry for the pics, can't get 1 to come out good
Old Nov 10, 2009 | 07:41 PM
TooLateVTEC's Avatar
Looks kinda like a BBC we had in a boat...gasoline got into the oil and took out all the lubrication the oil has and chewed **** up.
But I dont think it was that...were there any broken valve springs? With the carnage I would imagine there are. Maybe they were coil binding and broke but didnt drop the valve which in case you are lucky.
Old Nov 10, 2009 | 08:13 PM
all springs are intact as well as all lifters. nothing frozen up and no serious wear on the lifters(120,000 wear tracts only). oil was normal with no smell of gas at all
Old Nov 10, 2009 | 08:15 PM
oh and 40# of oil pressure on a hot motor
Old Nov 10, 2009 | 08:51 PM
S10xGN's Avatar
Looks like maybe some of the lifters were turning in the bores?
Old Nov 10, 2009 | 08:57 PM
SilverSS's Avatar
what kind of cam is that? i had an old comp cam that did that. upon examining the lobes that didn't have any damage, you can see fine surface cracks on them.
Old Nov 10, 2009 | 08:59 PM
NAVY99B4C's Avatar
ive had this happen to 2 older sbc enginesthey were flat tappets though. the answer i got from the cam company was that i broke the engine in with synthetic oil on both and they took the zync out of newer synthetic oils and that was what wore the lobes off of both of my cams they apparently were to soft of a compound, no thanks to them in the end. i broke in my cam in my ls i have now with mobil and havnt had a problem. there is no break in on a roller set up so maybe push rods to long binding the valvetrain? whats the lift? push rod length? lifters?
Old Nov 11, 2009 | 02:02 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
What cam is it? There has been issues on here amongst a couple cams with material issues. It could either be the hardening process, miscut, or another manufacturing issue.
Old Nov 11, 2009 | 06:18 AM
cam is from Thunder racing. pushrods are TR 7.4's on a stock longblock.
Old Nov 11, 2009 | 06:19 AM
stock lifters. cam is 230/224 575/563 110lsa
Old Nov 11, 2009 | 09:52 AM
Hmmm...
Do all the lifter wheels spin freely?
If so, I would say its the cam then.
I was thinking about the 'something got in the oil' idea, but the other lobes look alright.
Old Nov 11, 2009 | 02:21 PM
all lifter spin free. i'm starting to think it was a bad core. sad thing is it ran good. i only pulled it to sell the motor
