Question
Old Nov 15, 2009 | 02:12 PM
=ZoomZ='s Avatar
Default Question
I have a 404ci LQ9 , can i buy an LS2 block and swap out the parts (except pistons) ?
I have the dragon slayer crank and lunati billet rods , , will they still fit ?
Oil pump , timing chain , lifters , oil pan , cam ?
Old Nov 15, 2009 | 08:25 PM
Mighty-SS's Avatar
They are the same specs, the only diff I know is that one is Aluminum and the other iron so you should be ok with your swap
Old Nov 15, 2009 | 10:00 PM
TPl92z's Avatar
the main guts will all work but the pistons since they're .020 or .030 over.
knock sensors are in a different location along with some other things you can get around pretty easily.
