FYI : Head stud shortage
Old Feb 18, 2003 | 08:21 PM
LOnSLO's Avatar
Default FYI : Head stud shortage
Called several places today to locate ARP head studs, and everyone was out. I even called ARP, and they are not currently producing the LS1 studs. Finally found a set at Jegs. They have 1 set left.
Old Feb 18, 2003 | 08:42 PM
theblur98ss's Avatar
Default Re: FYI : Head stud shortage
Guess that's why I've been waiting 3 weeks for mine to show up.
Old Feb 18, 2003 | 08:49 PM
Phate's Avatar
You could also order a set from Dave (Formulation).
Check the FI forums, he has some custom studs that are stronger then the ARPs.
Scott
Old Feb 18, 2003 | 10:24 PM
Classic's Avatar
Ryan, glad to see you found studs. Now all you need to do is get the new heads out of hock an you'll be all set for this weekend. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Feb 18, 2003 | 10:27 PM
akw408's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Scott 98Z M6:
<strong> You could also order a set from Dave (Formulation).
Scott </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">His custom studs are also made by ARP, but with a different (more expensive) material so they are stronger than the regular ARP studs.
Old Feb 18, 2003 | 11:17 PM
BurnOut's Avatar
Tell me about it... I ordered some from Summit about a month ago, and they took ~2 weeks to come in; the Summit rep was telling me that the entire shipment of LS1 studs that they were expecting from ARP would go to fill back orders.
Old Feb 19, 2003 | 01:29 PM
Formulation'98's Avatar
Actually the last run of 20 sets we did was with another company called A1 Technologies, they do all of Katechs C5R head studs and all their other fasteners, also alot of pro race teams(top fuel on down) I have 12 sets left and they are ready to ship, also the lube I use is better than what ARP supplies(more consistant/uniform clamping force) they are H-11 material rated at 260-265,000 psi T/S...very strong, recommended torue spec is 80 ft/lbs this will provide about 15-16,000 lbs of clamping force. Let me know if you need a set at indacalinc@attbi.com , they run $375 shipped. Thanks Dave
Old Feb 19, 2003 | 01:30 PM
Old Feb 19, 2003 | 01:43 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
How much are the ARP head studs?
I need whatever head studs can handle 16-18 lbs of boost.
Old Feb 19, 2003 | 02:30 PM
smokin' joe 00 ss's Avatar
I paid $199.70 shipped from SDPC2000 they are the hex head.
Old Feb 19, 2003 | 03:29 PM
BTL FED's Avatar
Jegs has them in stock for 222.49 part number 070-234-4110, there website pulls that up as a main stud, but if you call it is the Hex Head Studs. These are getting hard to find.
