5.3 to a 383
Old Nov 20, 2009 | 09:05 AM
1nasty86's Avatar
Turd Gen Guy
Default 5.3 to a 383
im wanting to make my 5.3 into a 383 stroker. i know it involves boring it from 96 to 99mm but would this weaken the cylinder walls? because its a boosted motor.
Old Nov 20, 2009 | 12:01 PM
PREDATOR-Z's Avatar
Of course removing material will weaken the lining, but that does not mean it would not be enough for respectable levels of boost.
You could sonic test the block to find the best contender.
Old Nov 21, 2009 | 10:36 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We've seen a lot of 5.3l blocks bored to the 3.905" range. We can set you up with a 383 rotating assembly if you decide you need one!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
