Need advice on clearance issues
Old Nov 24, 2009 | 11:07 PM
massillongoat's Avatar
Default Need advice on clearance issues
I plan on running torquer v2 with 1.8 rockers I was gonna run my stock 241s worked over and milled .20 I need to know what ill nEed to do to make the pistons clear and how far u can cut the 241s
Old Nov 25, 2009 | 12:24 AM
ssfast99's Avatar
why did you choose that?
Old Nov 25, 2009 | 12:34 AM
PREDATOR-Z's Avatar
I would definately not run XE-R lobes with 1.8 rockers. That is asking valvetrain problems.
Old Nov 25, 2009 | 10:25 AM
So what would u suggest...I plan on. Having the heads ported and polished and milled to 62cc
Old Nov 25, 2009 | 04:15 PM
PREDATOR-Z's Avatar
Run it on a 112 LSA with 1.7 rockers.
Old Nov 25, 2009 | 06:14 PM
vettenuts's Avatar
Rather then cut the heads too much I would opt for a thinner gasket that will allow more timing to be introduced without detonation. I would just skim the heads to ensure the surface will be fine enough for a Cometic gasket so whoever does the milling must have the right equipment and take the pass slow.
