will these heads be enough?
FWIW the TEA 2.5's will put excellent numbers agreed Snake...but let's not side track Monkeys thread too much. It's his project and he should build it so he's happy with the part selection and so on since it's for his car.
Monkey what's the set up work out to be a 396 or something like that? I would really want that LSX intake with ~400 CID and that cam and good heads. That will give you way more than the other valves.
Likewise, If you give them your LSX intake to test with GTP might be able to alter the valve job on your current heads to get you max flow with the current valves and/or match the flow to your exact cam and intake. That and a little GTP porting on the LSX for max flow and I think this would be very cost effective way to make the best power with the 2.02 valves.
Of course I'll always be wondering what the TEA 2.5's would have done on your sweet set up
snake, i know that TEA does have some quick cars, but GTP has had several cars running mid 10s n/a on the S2 head. i am not naive, i know there are other great set of heads, i just prefer GTP for personal reasons...just like black bird prefers TEA..and others prefer MTI..and so on. i guess it was when i talked to craig @GTP for over 1/2 hour(on several occassions) that i decided this is where my money is going. i guess you can call me an attention *****
snake, i know that TEA does have some quick cars, but GTPl has had several cars running mid 10s n/a on the S2 head. i am not naive, i know there are other great set of heads, i just prefer GTP for personal reasons...just like black bird prefers TEA..and others prefer MTI..and so on.
Likewise, with your ~392 cubes, you might be able to get a little porting done on your LS6 intake. I think GTP has done that before for ~400 sized engines. Will cost some bottom end torque and help up top if I remember correctly.
1. upgrade to S3 with 2.05(or 2.08)/1.57(or1.6)valves only
2.full out port job with the larger valves and dual springs
3. just get 921 springs and go with bigger cam
4. just get some more port work done to the S2+ heads i have now.
but i am really leaning towards that S3 valve upgrade. i can sell the valves and springs(918s) to offset the upgrade. i have some wheels for sell, if i could get $300 bones for those, i would go all out on the S3 heads(the whole enchilada baby
) and ask craig to get 340+cfm. The Best V8 Stories One Small Block at Time
..i think you are right. i told craig i will stop by his shop after the holidays.
