some valve spring help
Old Nov 29, 2009 | 10:00 PM
mark.deady's Avatar
Default some valve spring help
i just got a set of used prc gold springs from a member on hear. i got the springs only. i am wondering if i will need some the rest of the stuff that comes in the kit or can i use the stock stuff... the biggest cam that i will go with is a 615 lift... thanks for the help and have a great night...
mark
Old Nov 30, 2009 | 04:38 AM
vettenuts's Avatar
If these are replacing stock springs you will need seats, retainers, locks and valve seals. Not sure what you paid, but used springs are a dice roll at best. Since the new kit is around $250, you may be better off just getting the kit. The other option would be PAC beehive springs that will allow use of your exsiting seats, retainers, locks and seals.
