Oil pick-up tube?
When I had my formula, after about 35k miles it starting knocking pretty good. The store manager at Midas (very knowledgeable guy) found a bulletin (not sure where) that it was common for I believe 01 and 02s, that when the pickup tube was installed into the oil pan, the rubber grommet would partially block the tube. So he ended up replacing lifters, push rods, and whatever else was associated. He even kept had kept the tube and showed me, and you could see the grommet was cocked and was covering it.
Well low and behold, my TA is now starting to do the samething. I was wondering if it would be possible for me to some how check this tube myself? I have read on here, that in order to remove the oil pan, you have to drop the motor. Something I definitely could not tackle.
Just looking for advice, a previous write-up, or what not.
To access the oil pan (drop) you need to lift the block, basicaly loosen motor mounts and jack up the block a bit (trans disconnected). It is doable with motor in.
I live in Houston and sometimes if i travelled North, like Colorado, I would switch from 20W50 to 10W40 to make it easier on the motor on cold starts. (SBC)
I can't say for sure what color the gromet was, just remember when he showed it to me (a few years ago) that you could see that it had been cocked off to the side, and was definitely blocking the tube.
I will become more concerned if it continues to do so, then go from there. I was just wondering if there was an easy way for me to check it, but don't think that is something I would be able to do.
Thanks for the replies.
