Flycutting piston help
Old Dec 5, 2009 | 02:32 PM
GTP PWR's Avatar
Default Flycutting piston help
what is the MAX you want to go on flycutting the pistons? is there a certain range? will it harm the piston if you take too much out and spray it?
Old Dec 5, 2009 | 02:53 PM
quick346's Avatar
i have a lsr cam 243/251 on a 110+4 .624/.624 and i have about .150 deep cuts on the intake side. i have sprayed 150 a thousand times
Old Dec 5, 2009 | 03:59 PM
GTP PWR's Avatar
Great to hear!! thats the amount I was going to cut!
Old Dec 5, 2009 | 11:14 PM
Zero4488's Avatar
Restricted User
YIKES!!!! I have a simillar cam with a .647 lift...I'm gunna have to go deep....
Old Dec 5, 2009 | 11:24 PM
G Engines's Avatar
The key to cutting your pistons is to only cut what you need to get the proper clearance required, I use .050 clearance on my intake and .100 on the exhaust. Any more and you can only make the piston weaker than they already are.
Old Dec 5, 2009 | 11:31 PM
01FbTaWs6's Avatar
im going to be cutting .080 on the intake side only, and leaving the exhaust side alone.
