Question about p-v clearance 228/237 cam
Old Dec 14, 2003 | 12:20 PM
foff667's Avatar
LS1TECH Sponsor
Default Question about p-v clearance 228/237 cam
after playing around with desktop dyno i think ive come up with some good specs on a cam it would be 228/237 .560/.560 112 w/ 2 degrees of retard it would make the same power across the board as tsp's 231/237 but with less lift...do you think i'll have any clearance issues with stock unmilled heads? From what i can see im probably not going to go with heads as unless they are milled or having a smaller chamber for more compression the #'s across the board just didntmake the power i wouldve liked for the money spent. I know its the thee most accurate way to go about picking a cam so you can give your opinions about that too if youd like, but if i can make the same #'s and have less valvetrain issues id be happy
Thanks
Bill
