Higher oil pressure after
Old Dec 14, 2003 | 12:36 PM
Drew778's Avatar
Default Higher oil pressure after
I replaced a broken valve spring, when the spring was broken I notice the oil pressure was higher (60 psi or a little above at 2000 rpm's)
Before the spring broke at operating temps the highest it would get was a little below 60 psi and even with the new Patriot springs insalled, I'm seeing higher then before oil pressure?
What could cause this? bad lifter, bent pushrod?
Thanks
Andrew
