Cam difference?
Old Dec 10, 2009 | 01:19 PM
Jwright41's Avatar
Default Cam difference?
Can anyone explain in layman's terms the difference between this cam MS3 - 237/242 .603/.609 and a MS4 - 239/242, .649"/.609. Will be going in a 2002 Camaro M6 with a set of new heads. MS3 with the PRC 2.5 5.3L (package) and the MS4 with AFR 205s. Pros? Cons? Car will be more of a weekend driver. Few trips out of town (600+ miles). Goal of 450+ rwhp and great torque. New intake to help or will the LS6 work just fine?
Old Dec 11, 2009 | 02:11 AM
Mighty-SS's Avatar
MS4 FTW !!! but you might have problems with clearance cuz the .650 lift... With stock pistons, I'll go with the MS3
But call Texas Speed, they will help you select the best cam for you !!!
Old Dec 12, 2009 | 09:02 AM
9secondsflat's Avatar
649 lift is quite a bit even with gold springs...stay safe around 600 is more then enough to benefit from any set of heads on the market.
Old Dec 12, 2009 | 09:07 AM
chevyman9306's Avatar
From what I have read and understand...if you go over like 615 lift you will have to fly cut your pistons so they won't hit the valve...maybe someone can chim in on the subject...
Old Dec 12, 2009 | 09:20 AM
BaddBird's Avatar
Its not the lift that causes ptv issues it is the duration.
