5.3 or 5.7
Old Dec 15, 2009 | 07:54 PM
hcb1700's Avatar
Default 5.3 or 5.7
Hi, I can get a great deal on a 5.3 LS engine, but wanted to know, is it worth building or should I just wait and get a LS1/6 or LS2? How much power can a 5.3 LS engine handle?
Old Dec 15, 2009 | 08:16 PM
hcb1700's Avatar
Also, will a T56 bolt right up to the 5.3L engine?
Old Dec 15, 2009 | 08:38 PM
white84z28's Avatar
Its hard to say whats worth building and whats not without knowing the specifics of the 5.3 you're looking at. I picked a 5.3 for my 84 camaro build because they are plentiful, they are cheap, and all ls components swap over. The 5.3 blocks are essentially an iron version of the LS1, they can actually be bored to about 3.905 safely. Ive heard those iron blocks are capable of supporting 1000+ RWHP. Yes a t56 will bolt up but you will need a LsX flywheel and clutch.
Old Dec 15, 2009 | 11:31 PM
hcb1700's Avatar
I'm looking at a long block for $200.
Old Dec 16, 2009 | 05:17 PM
Transamthunder's Avatar
grab it! In stock form other than rod bolts and a ls6 cam, here is a guy making it work.
http://1320video.com/pinksapp.php
and another:
http://s116.photobucket.com/albums/o...rshortpull.flv
Old Dec 16, 2009 | 05:20 PM
Just some turbo stuff these guys did with just cheap stock stuff, and a few key extra stuff.
Old Dec 16, 2009 | 07:46 PM
hcb1700's Avatar
I'm going to go ahead and get it. Good video.
Old Dec 16, 2009 | 08:16 PM
hcb1700's Avatar
What would be needed to install a TH350 or Th400 tranny on the LS motor? I'll add a T56 later on down the road.
Old Dec 17, 2009 | 02:37 AM
67firebirdak's Avatar
I think all you'd need is a spacer. The bell housing bolt pattern should be the same as long as your keeping it chevy/chevy and not going to a pontiac/olds/buick tranny.
http://www.summitracing.com/parts/HUP-HP3795/Application/?prefilter=0
And the spacer should work with both the LS1 5.7 or the LM7 5.3.
Old Dec 17, 2009 | 09:44 PM
BrownBoy's Avatar
Will an LS2 Flywheel/Clutch/Pressure Plate fit on the 5.3L (LM7)?
EDIT: After more searching...yes, it works!
Old Dec 17, 2009 | 10:43 PM
jgh64pkup's Avatar
i dont get how those spacers work
Old Dec 17, 2009 | 10:54 PM
hcb1700's Avatar
So will the spacer allow me to keep the transmission in the stock location, and prevent me from shortening/lengthening the drive shaft?
Old Dec 19, 2009 | 07:56 PM
hcb1700's Avatar
OK, picked up the motor today and it turns freely and everything. A long block(minus the intake) 5.3L for only $200. The guy said it ran and the reason he was selling it is because he needed the space in his garage and he was into traditional small block Chevy engines. Be prepared for a ton of questions.
Old Dec 19, 2009 | 11:41 PM
Paul57's Avatar
This forum is a wealth of knowledge.
Using the search function will help you out a bunch.
The only good thing about the traditional SB chevy motor is, it is cheap to build....but, you get what you pay for.
Your 5.3 should easily take a comparably built "traditional" 350...and get better MPGs (if that makes a difference to you).
Is this going in your '74 Vette??
Old Dec 20, 2009 | 12:51 AM
hcb1700's Avatar
Yeah, I'm thinking about dropping it in the vette. I've been searching through threads the whole day, but I might need to ask a couple of questions that I haven't been able to figure out, but I'll keep searching and if nothing, I'll ask the questions. Thanks
