trashed bearings, machine work
Old Dec 17, 2009 | 07:19 PM
crazygn's Avatar
Default trashed bearings, machine work
I found some bearing in the oil pan today so its going to be pulled. Engine runs great just teh bearing problem now, what machine work is needed to fix this. Didnt pull the crack and rods yet so let say its both rod and crack bears spun
Old Dec 17, 2009 | 07:40 PM
KCS's Avatar
KCS
Moderator
I can barely understand what the hell you are talking about (crack and rods? Bears?), but I think I got the jist.
Depending how bad and what spun, you may need a new shortblock. A spun main bearing can trash an entire block, and a spun rod bearing usually trashes the rod.
Old Dec 18, 2009 | 09:19 AM
bjamick's Avatar
Ya usually a spun rod bearing will tear up the rod surface. Usually all that's needed for the crank is it will need to be turned .001. Then just get the oversized bearings and your good. A bad machine shop can screw some stuff up though.
Old Dec 18, 2009 | 02:19 PM
crazygn's Avatar
i'll pull it this weekend if the snow holds off. Sorry for that post i was mad, drunk and in a rush haha.
Old Dec 18, 2009 | 06:49 PM
smontana16's Avatar
I dont understand what bearing you could have found in the oil except a needle bearing from one of the rockers. What did the bearing look like if its just a needle bearing from a rocker you just need to replace the rockers not pull the engine.
