Piston Ring Recommendations...
Old Dec 18, 2009 | 09:40 PM
gawath's Avatar
Default Piston Ring Recommendations...
I've been looking at the Hellfire/Akerly & Childs (supposedly the same), Total Seal and Sealed power rings. Most of the posts that i've found were in the Nitrous section. What's the ring recommendation for a stock bore piston (just a hone) that will seal well and have long life expectancy. I don't mind paying extra for better rings. No plans of nitrous/turbo. Will likely see heads/cam/basics.
Old Dec 18, 2009 | 09:51 PM
camaroz28lt1at's Avatar
As long as your not spraying or boosting, any of the above rings should be fine. Just gap them properly...
