Ticking in head after a mis-shift. Need help
Old Dec 19, 2009 | 10:13 PM
a.white86's Avatar
Originally Posted by black1999z28
I did all the valves,push roods,then I did the springs,pistons and rockers. I only did the springs, rockers and pistons because I replaced the cam when I had it apart. The valves only hit the pistons a little but to of the push roods were bent bad. I do not know how bad the springs and rockers were because I knew they were getting replaced after I saw that the valves hit the pistons. The other thing is that when I had the heads apart I could see where the valves where not seated on the heads all the way...I do not know if that was from the miss shift or from the miles on the car and all the passes on it. Let me know if you need any more info.
Ahh ok. yea I surely will do. I got ahold of some factory push rods so im going to replace all of the drivers side push rods with SLIGHTLY used ones. Guy has like a jug full of them and said I could have some. So im doing that tomorrow. Cross your fingers guys that I dont mess this up.
Is there anything I should know about taking the rocker arms off? Cuz I think I heard that theyre all on kind of a plate and they all come off at one time in one big piece? Next question, to take this "said plate" of rockers off, is it the bolts on the rockers that im unbolting to take them off?
All dumb questions I know, but this is my first time and I want to be sure im covering my A$$.
Old Dec 20, 2009 | 11:56 AM
a.white86's Avatar
Up to the top..
Old Dec 20, 2009 | 08:29 PM
redbird555's Avatar
Not too hard. Just unbolt the rockers and remember which one went on which pedestal not crucial but just to be safe. When you have the rockers off check and maker sure all the needle bearing are still in the arms and it rotates freely. Then there is a plate that goes on the head under the rockers but it merely just sits in place so its ok. Pull all the pushrods out and roll them along a table to see if theyre bent slide new ones in and torque the rockers to 22 ft lbs and your golden.
Dan-
Old Dec 20, 2009 | 10:23 PM
a.white86's Avatar
Everything is good to go guys.. Here's what I believe the problem was..
Old Dec 20, 2009 | 11:08 PM
Armageddon's Avatar
...with cheese.
I've replaced many a pushrod for guys that missed gears, it's not a big deal. Glad you got it figured out.
Old Dec 20, 2009 | 11:28 PM
one fast zo6's Avatar
i have never seen a pushrod bent that bad.
Old Dec 20, 2009 | 11:48 PM
-Q-'s Avatar
-Q-
Yeah, I'd say that was the problem
I bent one before that looked a LOT worse than that. Thing was at like a 45 degree angle LOL.
Old Dec 21, 2009 | 10:12 AM
VeTTeMaNC486's Avatar
that'd do it
Old Dec 21, 2009 | 07:55 PM
a.white86's Avatar
Haha.. Figured you guys would get a kick outta that! Thanks so much EVERYONE for their input. Cant tell ya how much a newB appreciates it. lol.
Old Dec 21, 2009 | 08:24 PM
Daryn's Avatar
Formerly darynC-10/23/10
i beg to differ
Old Dec 21, 2009 | 09:19 PM
-Q-'s Avatar
-Q-
Originally Posted by daryn c
i beg to differ
Now we're talkin'.
Old Dec 22, 2009 | 12:37 AM
  #32
i beg to differ
Holy ****, how do you people bend them that bad?
Stock push rods must be pretty bad.
I've been on the limiter HARD in the T/a a few times and never bent one.
Old Dec 22, 2009 | 12:55 AM
  #33
35th SS's Avatar
damm.try do that on a hardened one and see what happen.
Old Dec 22, 2009 | 02:38 PM
  #34
a.white86's Avatar
Originally Posted by -q-
now we're talkin'.
wow!!!
Old Dec 22, 2009 | 02:42 PM
  #35
a.white86's Avatar
Somebody made this for me the other day..
Old Dec 23, 2009 | 03:55 PM
  #36
396D1SS's Avatar
glad you found the problem, throw some chromemoly 7.4's so it doesnt happen again
Old Feb 27, 2010 | 04:55 PM
  #37
offroadfury6's Avatar
no, don't replace with chromemoly, or next time you may bend a valve insted of the much easer push rod. go back with stock, may save you ALOT of time and WORK.
