402 vs 408
Old Dec 17, 2003 | 07:25 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Default 402 vs 408
How much rwhp & rwtq would there be between the two motors( 4.00" vs 4.03" bores ) with ported 6.0L heads, 229/237/117 cam, and full bolt ons? This setup will also be used in a FI application so I would think the thicker cylinder walls of the 402 would be better. TIA
Old Dec 17, 2003 | 08:40 AM
CHRISPY's Avatar
408-409 would be just as strong.
You are talking a .03-.035 overbore on a 4.1 spaced motor. I would personally go with the 4.035 bore 4.00 inch stroke motor. (409ci)
Lots of room for overbores/hones and you can be sure everything is where you want it to be with bore roundness and spacing.
Cheers,
Chris
Old Dec 17, 2003 | 11:27 AM
z98's Avatar
z98
You're talking a few hp/torque at a few points on the curve, very little at the peaks.
Old Dec 24, 2003 | 11:22 AM
J.R.'s Avatar
I'd say 4-5 hp diff !
Old Dec 24, 2003 | 01:41 PM
The Guy in MY 99TA's Avatar
I'de give it 2-3 rwhp. Usually there isn't much affect of boring an engine from what I've seen.(well at least not .030 or so)
Josh S.
