problem:l76 not start in my camaro 3rd G
Old Dec 24, 2009 | 02:35 PM
m5q8's Avatar
Default problem:l76 not start in my camaro 3rd G
I have 2000 camaro , I swap yesterday l76 block with 241 head and ls6 intake , I use ls1 ecu and harnesses , what I need to start the car,
please when I turn the key the engine is turn but not run , like no ignition and no feul in injectors ????
and if I use a 24 relucator what should I use ???
I know complete the engine I will not open it another time ???
Old Dec 25, 2009 | 05:54 AM
m5q8's Avatar
no one ..............???????
Old Dec 25, 2009 | 02:02 PM
Armageddon's Avatar
...with cheese.
Make sure you remembered to plug the crankshaft position sensor in before you installed the starter. Check for fuel pressure to the rails. Make sure your coilpacks are plugged in and you're getting spark.
The 3 absolutes for an engine to run.
Fuel
Spark
Compression
Once those are verified you can work your way down to sensors.
Old Dec 26, 2009 | 05:28 AM
m5q8's Avatar
should I use ls1 crank ???
some one told me that ?
or what parts should I buy ???
Im in Kuwait I will order the parts
Old Dec 26, 2009 | 06:20 AM
butler's Avatar
24 tooth reluctor wheel or the adapter that lets the computer read the 58 tooth wheel on the crank
Old Dec 26, 2009 | 03:32 PM
m5q8's Avatar
what is this adapter ?
pics please and specific name?
