head up grade
Old Dec 27, 2009 | 11:45 PM
chevy99z71's Avatar
Default head up grade
I have a 99 Z71 with a 5.3. I have a blowed head gasket. Instead of doing a valve job on my heads a buddy of mine said he had a set of either 241 or 243 heads that had already be redone with a valve job. Any suggesting
Old Dec 29, 2009 | 08:56 AM
PREDATOR-Z's Avatar
You must mean 241 or 243 heads. 243s will work well if milled a bit, you'll need to use LS1/LS6 gasket. 241s have too big of a chamber and will negate any gain in flow (which is minimal) over your 5.3L heads.
799 (similar to 243s) will work well too.
Old Dec 29, 2009 | 10:46 AM
chevy99z71's Avatar
Would you use the ls intake or keep the stock intake. I am going to use the 241 heads for right now because i can pick them up cheap, and i know they are good so i dont have to wait on mine to get back,so i can get my truck back on the road.
Old Dec 30, 2009 | 07:13 AM
PREDATOR-Z's Avatar
Suit yourself, you'll loose about 4>5cc in chamber size, thus reducing compression and power output.
5.3L are 61.5cc and 241s are 67cc
You'll need to use LS1/LS6 head gasket, not 5.3L gasket which has a smaller bore.
Old Dec 30, 2009 | 07:51 AM
eseibel67's Avatar
Predator-Z: This guy isn't asking for a suggestion. He's going to do what his friend tells him.
It just feels better when the idea is confirmed by an expert.
Old Dec 30, 2009 | 09:44 PM
chevy99z71's Avatar
Thanks PREDATOR-Z for the information about the heads.
Old Jan 8, 2010 | 08:27 PM
Mark1si's Avatar
799 where used on the 5.3 and the 6.0 05-07 same casting as 243
