loosing coolant
I am brand new member of this great site. However, I have been to this site many times just reading the forums to answer my question. My most recent problem has left me stumped and I cannot find a thread that describes the same symptoms my car has. I have had my "new" 99 T/A for 10 months and LOVE it! Recently, as the weather turned colder, I have noticed the coolant light coming on). I added coolant the first time not thinking too much about it. A couple weeks later, it came on again. I looked over the system and didn't see any leaks. I also checked the oil and coolant, but i didn't see any cross contamination. I added again and took it to my local garage. They pressure checked my system and found no leaks or loss of pressure. Just a couple days ago, I smelled antifreeze, so I popped the hood and discovered coolant leaking from the cap on the recovery bottle. I haven't modified anything since I have had it, and drive it everyday. I occasionally have a little fun off the line, but most of the time I baby it around. (no sense in jackrabbiting from a red light just to have shift gears in rush hour traffic all the time)
The weird thing is, it may loose enough coolant to set the light off in a couple of days, or it may take 2 weeks, and I am driving it the same way the whole time. The temp gauge never passes 200 degrees. I have noticed the typical valvetrain "tick" all LS1's have. It started about 2 months before the coolant problem. I wouldn't think this would cause anything coolant related, but i'm just at a loss on this.
Any ideas? Thanks a bunch
The Coolant level sensors often can get gunked up and set a false low coolant light, even though the coolant level is fine. My T/A did it before, and my Grand Prix used to do it all the time.
So you add coolant thinking its low, but its actually not. This causes the coolant level to be too high, overfilling the coolant reservoir when the engine becomes warm. Which would explain why you saw it overflowing out of the reservoir.
Let us know if that sounds like it may be a possibility.
I just rebuild my motor and when I turn it on coolant drips out the bottom near the K member at a vast rate and looks as if its coming from the oil pan. I don't think I'm over filling the coolant level. You know what would cause this?
Thanks a WHOLE bunch!
