ls1 IS THIS NORMAL????
Okay so here is the story; please give any/all advice.
Looking at a 2000 trans am with a built bottom end and 5.3l heads. Has a beck sheetmetal intake and cam. Exhaust is hooks headers no cats to muffler. Radiator is only filled with water.
So i went to look at the car, it started right up no problems. Some exhaust leaks under the car and a little from between the headers and heads. It blows smoke that disepates into the air like a normal car that is cold, but it keeps doing so even when the car warms to operating temperature around 200. Car does not run hot even when idleing for 15 minutes with electric water pump off. Car is dumping alot of fuel with 120lb injectors the gauge on the fuel rail is reading 60psi. Car has been sitting over the last 8 months but shouldnt it not have so much exaust smoke coming out of it?
ALSO THE AIR FUEL GAUGE READS 13-15 AT IDLE
But anyways my valve seals are bad, the stock rockers cannot handle the ramp rate of the cam.. Solution is roller rockers
https://ls1tech.com/forums/negative-...ud-beware.html
Something to consider....
btw the console arrived broken!!!!!!!!!!
Also if this car was running on race fuel and I put 93 in it because there is no place around to buy race fuel at, would I do any damage as long as I keep the car under 3k rpms?
Good luck. Sounds like there are a lot of issues with the car. Sure you can sell the intake, EWP, and a few other things. Again, good luck.
