which lifters ls7, morel?
Old Jan 8, 2010 | 09:23 AM
bluehawk2's Avatar
Default which lifters ls7, morel?
I have read a lot of threads about ls7 and morel lifters. I know it makes a difference which cam you are using when determining the rest of the valvetrain.
This is my cam.... "CheaTR" - 214/230 .601/.575 117 LSA.
what should I use for the rest of my valvetrain?
Here is what I was thinking
Dual Springs
Ls7 lifters
Stock rockers with the Comp trunion upgrade
thanks for any info!
Old Jan 8, 2010 | 09:33 AM
Jon@Texas-Speed's Avatar
The LS7 lifters and stock rockers would work fine for that cam. I wouldn't be concerned at all. The Morels would be a little nicer lifter but the LS7's should do the job for you. If you are concerned about running the stock rockers, you can do a trunion upgrade to get rid of the needle bearings you'll be good to go!
Jon
Old Jan 8, 2010 | 10:14 AM
bluehawk2's Avatar
thanks! just wondering if I was on the right track
