A fast, easy way to measure preload.
Old Jan 13, 2010 | 07:04 PM
firstinlastout86's Avatar
Default A fast, easy way to measure preload.
Fast and Easy Way to Check Hydraulic Lifter Preload when using Non-Adjustable Rocker Arms (Found on Crane website ENJOY)
With the cam, hydraulic lifters and pushrods in place, install your rocker arm assembly. Use the prescribed method in your repair manual and torque down all the valve train bolts in the proper sequence. Pick a cylinder that you are going to check. Hand rotate the engine in its normal direction of rotation until both valves are closed. You are on the compression cycle for that cylinder. (At this position the valve springs are at their least amount of tension making the job a little easier to do.)
Wait a few minutes, allowing the lifters to bleed down. Now, lay a rigid straightedge across the cylinder head, supporting it on the surface of the head where the valve cover gasket would go. Using a metal scribe and the straightedge, carefully scribe a line on both pushrods. Now carefully remove the torque from all valve train bolts, removing any pressure from the pushrods. Wait a few minutes for the pushrod seat in the hydraulic lifter to move back to the neutral position. Carefully scribe a new line on both pushrods.
Measure the distance between the two scribe marks, it represents the amount of lifter preload. If the lines are .060" to .080" apart you have proper lifter preload (for LS7 lifter). If the lines are the same or less than .020" apart you have no, or insufficient, preload. If the lines are further apart than .060", you have excessive lifter preload.
Old Jan 13, 2010 | 07:17 PM
1MtnGoat's Avatar
Default May not work!
This will not work on my engine. The push rods are below the valve cover rail so one cannot mark them. I checked this on both my Edelbrock heads and stock "241" heads.
Old Jan 13, 2010 | 09:14 PM
S10xGN's Avatar
Hard to imagine a reputable company telling people to "scribe a mark" on something as highly stressed as a pushrod. Buy Carroll Smith's "Engineer to Win" and see what a pro has to say about stress and stress risers...
Old Jan 13, 2010 | 09:25 PM
Ya i was thinking the same thing but then again Crane isnt around anymore right?
