will LS7 springs work on LS1 heads?
Old Jan 15, 2010 | 11:52 AM
lifted99GMC's Avatar
Default will LS7 springs work on LS1 heads?
I was just needing a quick answer hopefully someone knows so i wont have to peel off a spring. they are most likely good to .600 lift from the factory since the stock LS7 cam is .59X" lift. Are the stocl LS7 springs dimensionally the same? are they a direct swap, or does any special machine work need to be done? I have a set of these springs on my C6Z and was hoping I can use them with a small TR 224 cam.
thanks for any info.
Old Jan 15, 2010 | 12:06 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
The spring will fit into the LS1 spring pocket without issues....HOWEVER, the LS7 spring sets up at a taller install height than the LS1's typically do (1.959" IIRC). If you put the LS7 at 1.800", you'll see about 145# seat pressure. The spring will not from there allow you even .550" valve lift though, so it's utterly useless to you.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jan 15, 2010 | 12:37 PM
Thanks, I appreciate it! I'll be giving you guys a call shortly.
