What valve spring is this?
Old Dec 20, 2003 | 05:02 PM
Toonz's Avatar
Default What valve spring is this?
Can anyone tell by looking what kind of valve spring this is? I bought my car with the new heads/cam already installed and these springs. This one broke and I need to replace it and am hoping to shed some light on what they are. TIA.
BTW - Any reccomendations on which ones to go with? I have a 224/230 .581/.572 cam with stage II heads.
Attached Thumbnails What valve spring is this?-bs01.jpg   What valve spring is this?-bs02.jpg
Old Dec 20, 2003 | 08:07 PM
NA$TY-TA's Avatar
To the Top for ya Rob..... Did you call Jaun and ask?? Give me a call later.
Kyle
Old Dec 20, 2003 | 09:47 PM
95LS1TA's Avatar
A broken one!!!!
Old Dec 20, 2003 | 10:39 PM
jrp's Avatar
jrp
SN95 Director
kind of hard to tell by just looking at it, not many single springs with dampers out there.
if you want a single spring then look into the 918's or manleys. you want duals then go with some revs, comps 921, cranes, or PP duals.
Old Dec 20, 2003 | 10:47 PM
Slowhawk's Avatar
LS1Tech Sponsor
They are not 918's,cranes or Manley's.Haven't worked with those before.
If 1 breaks your better off changing them all.
Old Dec 20, 2003 | 11:04 PM
jrp's Avatar
jrp
SN95 Director
could be a cmotorsports ex-615 or ex-616 spring.
http://www.cmotorsports.com/images/E...Spring_Kit.jpg
Old Dec 21, 2003 | 03:08 AM
Toonz's Avatar
Hmmm, thanks for the input guys.
The retainer saved my a$$ on this one so I know I want a single with retainer or a double. Guess I'll be spending a bit more $ than I orginally thought.
Old Dec 21, 2003 | 02:15 PM
silverTA's Avatar
what kind oe heads,cam u got
Old Dec 21, 2003 | 02:24 PM
Ferocity02's Avatar
I'd say replace all of them. It's cheap insurance. If one broke, the others might as well also.
Old Dec 21, 2003 | 02:44 PM
GTBMad's Avatar
Looks like a Comp 941
Old Dec 21, 2003 | 04:28 PM
v8maro's Avatar
Thats not a comp, looks like an Isky D95.
-Steve
Old Dec 22, 2003 | 02:08 AM
Rod's Avatar
Rod
Looks like a pioneer stock style s.b. chevy spring, all the Isky 295-D I have seen have a gold stripe. I would check the pressure on the good ones and that will give you an idea on what rate per inch you have to narrow the search down on what you have.
Old Dec 22, 2003 | 02:56 AM
sbrown99TA's Avatar
The EX 616's have a bright, bright red stripe and the 615's have a black stripe I think.
