383 stroker cam choice
You know it always sux to spend money and time on your ride only to find out that it made no defference or worse, it made it slower.
what heads & other add on's???
personally i have seen better flowing heads make the biggest difference than a cam swap.
Sure they cost more but it may work out better in the long run. The more effiecent the motor flows the more power it will make. You can only push som much air through a head, even if you get the biggest cam in the world.
I would do a FAST 90
Do an 04 ZO6 MAF
DO a 90MM port/polished TB
Like stated before better heads, with complimenting parts will make a hell of a difference.
